Need help with LOW TRAC!!!
Old Aug 14, 2006 | 01:52 PM
HummZ28's Avatar
1995 Z28 6spd. I need help with a little issue I'm having with Low Track. When coming to a stop, (doesn't matter what speed I was traveling) around 5-10 mph Low Trac is kicking on and the breaks let go for a split second on dry pavement. I'm not hitting the brakes any harder than normal. I checked brake fluid, checked for leaks, checked sensors, checked fuses, I'm wondering if anyone may know what the problem is. Thanks.
Old Aug 14, 2006 | 05:54 PM
Re: Need help with LOW TRAC!!!
Have you checked the sensor in the rear axle housing for magnetic particle buildup?
Old Aug 15, 2006 | 07:57 AM
Lunch Box's Avatar
Sounds like what my truck did when the ABS wheel speed sensors went on it, but you said it was a Low Trac problem and you said you already checked the sensors, so I dunno what it could be.
Old Aug 15, 2006 | 09:36 AM
OBE1 95Z28's Avatar
I had the same issue. As Fred stated above, check/clean your ABS sensor that's mounted in your differential.
Old Aug 18, 2006 | 07:28 AM
HummZ28's Avatar
Thanks for the help, I'll check the rear axle.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
