Need Frame Builder with Surface Plate.
1969 CAMARO Z28 RS DZ “F” BODY COUPE
It will be an Upgraded 69 Z28 Muscle Street Car.
When I bought the car in 1976 100% original, who ever repaired the rear hit, hack it up and did not replace the kinked rear frame rails which are not available now.
1. I will supply sub frame, pair of 69 Camaro OEM shaped “PROFILE RAILS” 2X3X11ga box steel rails from autoweldchassis.com and the Print with all Dimensions.
2. Build on a holding fixture and off rear OEM sub frame (no body) and add the “PROFILE RAILS” (mid and rear frame section) to OEM Horizontal & Vertical Dimensions.
3. I will also compensate for any addition or material provided.
Email leolhaudek@comcast.net your estimated quote, how long to build after you received all the parts, your phone number and address so we can meet in person.
If you can do this, or recommend someone that can, Funds are waiting.
Thanks,
Leo L. Haudek
Warren, Michigan.
Thanks,
Leo L. Haudek
Warren, Michigan.
RX Speed Works
Sep 11, 2015 03:31 PM
