Is my window motor shot?
I had my window down for a couple days in the garage. Today it wouldn't go up. Other one works fine. Took apart the door, nothing is obstructed. I can't get the window up no matter what. I thought it might be electrical problem but when i push the button, i hear a click from the motor but no movement.
Is it typical for them to go out w/o warning? It worked perfectly fine (and still had good speed) the last time i used it. No one has been near the car and nothing damaged it. I was under the impression that they fail slowly. Anything else i should try before I order a new one?
Re: Is my window motor shot?
I had a regal where you could hear a thunk with each press of the switch. Thought for certain is was the window motor. After trying two motors it turned out to be the switch.
Thanks guys, Ill see if i can rig it up to the other switch. You saved me the hassle of buy ing a new motor. Yeah thats what I thought, a failing motor would die slowly, this one worked perfectly fine the other day.
WEll i took apart the door checked everything, I started tinkering with the wires attached to the switch and it started working perfectly again. Im guessing it was a loose connection. Im gonna watch it and see what happens next, hopefully its good now.
Lt1son
Dec 31, 2014 01:35 PM
