Moved battery to rear, what size fuse?
Old Sep 24, 2005 | 10:45 AM
RacerTim's Avatar
I moved my battery to the rear of the vehicle and ran 2ga power wire to a distribution block up front. I had it fused with a 150amp but it keeps blowing every other time i start the car. Obviously the fuse isnt big enough. What size fuses are people using? I have also heard from several racer friends that I should just run a shut off switch instead. Its a street car so a shut off switch on the outside of the vehicle there isnt an option. I really don't want to have to run the 2ga wire up throught the center console either. What things have other people tried? Or, to keep things simple I would just rather get the right size fuse and not have to worry about it. I'm ordering 200amp fuses today to try in there.
Old Sep 24, 2005 | 12:53 PM
RacerTim's Avatar
Re: Moved battery to rear, what size fuse?
Nobody has a fuse on their rear mounted battery?
Old Sep 24, 2005 | 03:02 PM
RE AND CHERYL's Avatar
I've never actually seen a fuse on a rear mounted battery, but now that you mention it; why wouln't you install one. The starter alone draws about 200-250 amps during a normal start. If the engine is hot or the starter is old I imagine it could be a lot more. If your going to use a fuse. Get one that is rated for what the cable can cary based on gauge and length. That way you wouldn't hurt or fry the cable in the event of a short. The problem is even if you don't hurt the cable, you'll burn through the the sheet metal in a second. That cable caries way more juice than your average welder.
Old Sep 24, 2005 | 03:27 PM
Dave89IROC's Avatar
200 might do it for you, but if I was going to fuse it, I would use a 350 or 400amp fuse, right at the batt
you can find them at boat supply stores
Old Sep 24, 2005 | 03:42 PM
TedH's Avatar
I have a shutoff switch. Not legal at the track without it. I also needed a NHRA approved battery box and an outside vent.
HectorM52
Jul 30, 2017 11:46 AM
nosliw
Feb 7, 2015 01:30 PM
JSK333
Sep 9, 2002 10:33 PM
$hawn
Aug 17, 2002 04:37 PM
