Metal cutting tool
Metal cutting tool
I was looking for a hand held tool to be able to cut through smaller metal like LCA brackets. I was thinking a Sawzall or a Dremel. You guys have any suggestions?
Re: Metal cutting tool
Originally Posted by convertz
Your gunna want to shoot yourself if you try cutting a LCA bracket with a dremel. Sawzall or the cutoff tool is a better way.
Plasma Cutter?
Plasma Cutter?
Dude, Plasma cutter?? Way too expensive. For what he's looking at doing. Yeah, the cut off tool is the way to go. Pluss you can use this for a lot of other things. Like grinding down the sharp edges from the piece you just cut. Dremel is good for small fine tuned work, like porting and polishing stuff.
You can do a LOT w/ this.... strap a cutting blade on it and you're good to go. MUCH cheaper than a plasma cutter. Although that PC would be fun to mess around w/...
Aug 24, 2015 06:41 AM
Aug 7, 2015 08:52 AM
88IROC_Z
Jul 22, 2015 11:38 PM
Catmaigne
Jul 14, 2015 05:17 PM
