maybe another dumb intake question
Old Jun 8, 2007 | 04:22 PM
oneclean97z's Avatar
i recently put on a cool air intake kit. question is do i leave it hanging there inside that "box" of plastic and such that the old air box used to be above, the one right by the fender, or can i remove that plastic material stuff so the filter is literally exposed to the open air, i feel like more power would be gained that way. what has everyone else done with theirs? thanks in advance
Old Jun 8, 2007 | 04:23 PM
96ZCamaro's Avatar
I do not understand what plastic stuff you are talking about.
Old Jun 8, 2007 | 04:29 PM
chevycamaro210's Avatar
IF YOUR TALKING ABOUT THE STOCK FILTER BOX I REMOVED MINE IT GETS MORE AIR LIKE THAT.
Old Jun 8, 2007 | 04:39 PM
JAB's Avatar
JAB
I'm not sure exactly what you're talking about but if you mean leaving it exposed to open air down below out of the engine compartment in front of the tire I'd be wary. It would be pretty easy for it to suck up water or be hit and cut open by road debris.
Old Jun 8, 2007 | 04:48 PM
yea to where it would be in open air instead of in the "box" it currently is in. i am heading into work but will check back later. thanks for input everyone
Old Jun 8, 2007 | 05:45 PM
2000GTP's Avatar
I agree, I would leave it in place.
Old Jun 8, 2007 | 06:50 PM
OrbitalChris's Avatar
I took mine out..its theway to go haha
Old Jun 9, 2007 | 06:53 PM
WestCoast96Z28's Avatar
I've seen people take the "cover" off or even try to do a "ram air" thing adding a scoop down there. But same people complain about getting the filter wet in bad puddles. To compromise, yoiu could drill holes in the plastic bottom part.
I notice on mine that the cover's there, but this is a slight opening...about 1/4" wide and about 6" long.
Old Jun 10, 2007 | 10:04 PM
well my cover thingy that was directly below the cone filter had slits in it but were facing opposite direction of the blowing air when moving forward, dont know if those were to help air intake but its how it came from the factory but i removed that whole piece and notice a difference on highway speeds now
LT14LIFE
Feb 9, 2015 09:35 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ModdedNerd
Dec 25, 2014 05:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
