m6 vibration at 55 mph?
Old Mar 26, 2013 | 10:08 PM
EdgarArmada's Avatar
My car vibrates hard at 55. I can feel it in the shifter and center console. Does this sound like a bad tranny mount or what could it be?
Old Apr 16, 2013 | 05:43 PM
blue's Avatar
Re: m6 vibration at 55 mph?
Probably not the trans mount. Mine was broken on an m6 and it drove fine. I would check the tie-rods. Jack up the front wheel and wiggle it left and right. If it will turn at all without the steering stuff moving, the tie-rod is shot which means it will be wiggling freely like that while you drive. The other possibilities are an alignment, a bulge in a tire, or an incorrectly balanced tire (one of the weights came off). I once had tired mounted on a corvette and the guy did a sorry job and the vibrations became noticeable at about 60.
If your vibration is specifically in the trans, I would suspect maybe a shot u-joint. The driveshafts are also balanced and whatever way they come off, they have to go on again, but I think the weight is welded on it.
95chwagon
Oct 16, 2015 12:24 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
NewsBot
Sep 14, 2015 09:20 AM
mmf_1013
Sep 12, 2015 08:56 PM
