lubrication . . . not what you think
Old Jul 26, 2004 | 05:10 PM
Camerone222's Avatar
I have tried several common products while trying to get my doors to stop sqeaking, with no success. Things like WD-40, grey lub that my dad had, etc. Anyone know of something good and cheap so I will not have to hear that annoying sound every time I open my door?
Cameron
Old Jul 26, 2004 | 05:21 PM
unvc92camarors's Avatar
Re: lubrication . . . not what you think
how about silicone grease?
you can find it anywhere and it won't wash off like wd40 or anything like that
Old Jul 26, 2004 | 05:25 PM
Spinner's Avatar
Silicone spray works pretty good. White lithium is good stuff as well and wont go away like sprays
Old Jul 26, 2004 | 05:37 PM
HBHRacing's Avatar
a good cleaning followd by white lithium should help
Old Jul 26, 2004 | 09:31 PM
And you can even get the lithium in a spray!
Old Jul 27, 2004 | 11:31 AM
sweet guys thanks for the help
Cameron
Old Jul 27, 2004 | 11:52 AM
slayer6x6's Avatar
Another vote for white lithium, do your hood latch while your at it.
Old Jul 27, 2004 | 12:04 PM
do most auto parts stores carry white lithium/what is the best place to get it
Cameron
Old Jul 27, 2004 | 03:37 PM
RealZ28's Avatar
I used some key grease on mine. It's very similar to white lithium except it's a bit thicker...almost like cold pudding. Seems to work great
Old Jul 27, 2004 | 05:32 PM
HBHRacing's Avatar
yes most places carry white lithium. come sin an arosol can.
Old Jul 28, 2004 | 12:48 PM
DarkRider's Avatar
I just used swome red synthetic grease that I had laying around, worked good
Old Jul 28, 2004 | 01:51 PM
teke184's Avatar
a common mistake people make when trying to lubricate something is using a product like WD-40
it reallly isn't a long term lube. it evaporates fairly quickly. and at the same time it disolves and washes away any previous lube that was on there.
it is ideal for losening rusted or corroded parts, but following it's use, the piece should be lubed witha propper grease or oil.
Old Jul 28, 2004 | 02:46 PM
OutKast's Avatar
white lithium in a spray can will work the best for you. When it first comes out of the can it's wet, after a couple minutes it thickens up. This is good because when it's wet it runs down in the places where you want it and then turns thick. With other grease, you just have to hope that it works it's way into the squeaky spot.
IrocSS85
May 29, 2005 04:10 PM
pHEnomIC
Oct 23, 2004 10:29 AM
ibanez6rg
Jan 16, 2004 09:50 AM
MentalCaseOne
Dec 3, 2003 07:32 AM
iCE
Feb 14, 2003 08:01 AM
