lt1-ls1
Old Oct 24, 2004 | 11:44 AM
cndctrdj's Avatar
lt1-ls1
so how hard would it be go from an lt1 to and ls1 in my car. i need a new motor so i figured i would go with something a bit newer than what i have. any suggestions? or would it be better to get an lt1/lt4 and work on that instead?
Old Oct 24, 2004 | 11:50 AM
Kataklysm's Avatar
Re: lt1-ls1
From what I understand it is alot easier and cheaper to build an LT1 then it would be to swap to an LS1. For the same price you could have a stock LS1 or you could have a heads and cam LT1 with some other minor stuff done to it. Someone just made a post about this the other day, you would also need an ultra Z type hood so you can make the LS1 air intake system work correctly.
Old Oct 24, 2004 | 12:26 PM
Capn Pete's Avatar
Re: lt1-ls1
It can be done, and it has been done, but an LT1 -> LS1 swap isn't just a simple "re & re", there's a fair bit of work involved, and you need a different hood on an LT1 car to clear the LS1 intake. Plus, all the wiring/electrical hook-ups are all going to be different, and you need the computer and everything else........ too much work for me!
I think you'd be better off building your LT1 up to LT4 spec's (intake/heads in particular), with a good camshaft, and you'd probably out-perform a lot of LS1's.
Old Oct 24, 2004 | 01:08 PM
cndctrdj's Avatar
Re: lt1-ls1
ok so hwo hard would it be to get an lt4 and put that in
Old Oct 24, 2004 | 01:44 PM
Kataklysm's Avatar
Re: lt1-ls1
If you have an LT1 now you can just buy the LT4 conversion kit. But for the price its cheaper for you to go out and buy a better head/cam combo and you will make more power. An LT4 is an LT1 with a different cam, intake and set of heads, visually it looks the same other then the red intake manifold.
Old Oct 24, 2004 | 04:34 PM
Kris93/95Z28's Avatar
Re: lt1-ls1
I have seen first hand what a motor swap entails...
My experience was a friend's V6 ~ LT1 swap.
I can tell you just find a LS1 Car and buy it if you want an LS1.
Else I would suggest, as above, build a mean Heads/Cam/Full Bolt-On LT1 that spanks mildly modified/unsuspecting LS1s
Old Oct 24, 2004 | 08:00 PM
GreenDemon's Avatar
Re: lt1-ls1
Why get an LT4? Aftermarket heads and cams will get a lot more power than an LT4 swap, especially now that vendors are coming out with LT1 head castings.
Old Oct 24, 2004 | 11:44 PM
cndctrdj's Avatar
Re: lt1-ls1
well i think i have a good idea. im looking at a used lt1 with low milage on it. i am going to buy that motor and put it in my car. then im taking the old motor and building that from the bottom up. that way when i get the "old motor" done i can swap them and have somethign else to build up differently
Old Oct 25, 2004 | 11:30 AM
camaro81's Avatar
Re: lt1-ls1
an LS1 isnt THAT much better than the LT1, its definatly not worth the trouble to change :P
hell both mine run about the same ET and there aint much done to the LT1
why would you wanna switch?
Old Oct 25, 2004 | 11:24 PM
cndctrdj's Avatar
Re: lt1-ls1
just for something different
i do love my lt1 (when it ran)
im just trying for as many opportunities as i can find
i do like the idea of having an extra engine on tap that i can work on and build up
gcouse7
May 27, 2011 01:21 PM
.383 LT-Gun
Jun 21, 2010 03:23 PM
95z28 -quicksilver
Parts Wanted
May 1, 2010 07:44 PM
flynlow
Parts Wanted
Jan 4, 2008 08:57 PM
ucrazymonkey
Mar 2, 2003 01:06 PM
