LS1 MAF on LT1 Engine
Re: LS1 MAF on LT1 Engine
Check the P/Ns, if it's the same P/N then they are interchangable. If they are different don't use them; most likely the flow curve (Airflow Vs frequency); which is what your PCM sees to read the airflow is different.
The only way to make it work would be to have the correct flow curve/table and modify/adapt the curve for the LT1 PCM, and have the correct pigtail.
formula218
Dec 2, 2014 04:27 PM
Jul 4, 2005 05:00 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
