low coolant level light is on
Old Dec 21, 2006 | 10:27 AM
TJsrh420's Avatar
and it won't stay off. it comes on about 10 min. after starting. anyone have a clue why? can't seem to find a level sensor. is it in the rad?
Old Dec 21, 2006 | 10:34 AM
teke184's Avatar
back side of the radiator, must under the fill cap. i think there is a hose above it.
sensor goes bad and reads inaccurately....VERY common.
you can unplug it with no side affects...other than not having the sensor any mroe.
Old Dec 21, 2006 | 10:39 AM
TJsrh420's Avatar
any good pics of that?
Old Dec 21, 2006 | 11:22 AM
teke184's Avatar
i don't...i think shoebox has one on his page
but honestly....if you can find the radiator fill cap...you are 3" from the sensor plug.
Old Dec 21, 2006 | 12:06 PM
OBE1 95Z28's Avatar
Here's a photo from Shoebox's site: http://shbox.com/1/low_coolant.jpg
Easy to access with the battery removed. The sensor is a common failure; it also doesn't cost that much and is easy to replace.
Double check that your radiator is full to be sure you don't have a real leak.
Old Dec 21, 2006 | 01:38 PM
TJsrh420's Avatar
thanks a lot guys. had a horrible day today and this just atleast put a smirk on my face
Old Dec 21, 2006 | 02:53 PM
DJ_951's Avatar
OK back to the bad day. Check the waterpump little weap hole for fluid. When the water pump is getting ready to go out the bearing runs hot and water leaks out the hole on the bottom. Ask for another opinion but this too will turn on the light.
Old Dec 21, 2006 | 04:11 PM
OBE1 95Z28's Avatar
That being a real leak, it which case the radiator would be down on fluid, causing the low coolant level light to come on, as it should.
Old Dec 22, 2006 | 09:47 AM
DJ_951's Avatar
I missed the part where he said it didn't loose fluid or didn't just fill it up.
You can clean the sensor too, the hole can get plugged.
BMX Dad
Jan 23, 2015 07:00 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
