Little red box?
Old Jan 13, 2009 | 06:48 PM
97'Z-28's Avatar
Little red box?
I have been having trouble starting my car sometimes and all I have to do is wiggle the positive(red) wire on the red box on the passanger side fender near the battery and It will start. I try to tighten the nut and the whole stud spins so it wont get tight. Where can I find this part?
I checked with a chevy dealer and they said it was discontinued.
Old Jan 13, 2009 | 07:54 PM
mrmint69's Avatar
I ordered one from the dealer last year so Im suprised its not available. Check Ebay.
Old Jan 13, 2009 | 09:30 PM
Green96Z's Avatar
It's not discontinued as far as I know. I bought one from the dealer about a year ago. It's GM # 12186586.
Old Jan 13, 2009 | 09:34 PM
ak95ta's Avatar
And its only +/-$12.00
Old Jan 13, 2009 | 10:22 PM
97'Z-28's Avatar
alright guys, thanks alot. I'll check the dealer again tomorrow and give them the part #. what would this box be called? I cant come up with anything on ebay.
Old Jan 13, 2009 | 10:27 PM
Green96Z's Avatar
Wiring block, junction block, something like that. Just have them pull up the picture and point it out to them.
Old Jan 13, 2009 | 10:50 PM
mrmint69's Avatar
Mine was missing the cover so it looked weird to see it whole again. My voltage issue appeared to get better after replacing it. I cleaned all the connections to and from it when I replaced it.
Old May 12, 2009 | 03:08 PM
Brangeta's Avatar
How did you clean the gunk out of that area? I need to replace my little red box as well, but not sure what to use to clean the 10 years of gunk out with.
Old May 13, 2009 | 06:54 AM
DAVE00's Avatar
Try here:
http://www.gmpartsdirect.com/
$10
Old May 13, 2009 | 09:30 AM
Brangeta's Avatar
That's weird! They didn't have it come up in search results yesterday, as if they were out. I emailed them yesterday, so maybe it did some good...? Wish it would have come up, because I ordered one from a local dealer for $15.
Old May 14, 2009 | 11:50 AM
BLKOUTZ28's Avatar
http://www.hawksthirdgenparts.com/93...otorkit-1.aspx
Old May 16, 2009 | 05:16 PM
dvdslw's Avatar
That red box is just a junction where the battery cable and alternator cable come together. You could just remove the stud and replace it with a nut and bolt to hold them together. The red casing should still be used to insulate the connection.
HOFFICER
Apr 6, 2020 10:36 AM
RUENUF
Mar 13, 2016 03:39 PM
Collector Car
Dec 17, 2014 01:12 PM
