lights problem
Old Jul 26, 2005 | 11:25 PM
Doug94TA's Avatar
lights problem
Ok, I'm just about done converting the front end of my car to the 98-up. All the wiring is done, and everything was working fine. I noticed that one of my turn signals bulbs was out so i thought i would use a test light on it to make sure it was the bulb. Well i must have touched the side of the socket and it sparked a little and now all of my lights are messed up. It blew one of the headlight fuses so i stole one from the radio slot temporarily. None of the other fuses are blown that i can see. Both the low and high beams work correctly, but the fog lights now turn on only with the high beams, and the turn signal bulbs and marker bulbs don't work but will flash if i turn on the turn signals. Also the dash lights are out on the inside. I am clueless, and the car is being dropped off at the paint shop tomorrow so i need to figure this out. Any help would be appreciated.
liamcg97
Nov 25, 2019 05:55 PM
eazyZ
Mar 1, 2015 07:12 AM
MattFick
Feb 15, 2015 10:16 PM
97z28k&N
Jan 9, 2015 04:58 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
