Light weight batt.
http://www.brailleauto.com/productca...17&idproduct=7
Sitting on the stock tray, requires side-bolt conversion terminals to attach to stock cables. Held down by a custom made 1/8" thick polished aluminum strap, bolted to the stock bolt location in the back, and the radiator cross-support in the front. Maintained with a Battery Tender Plus, since the car sits unused for extended period of time.
Thanks, thats a good link. Do you think i could dd a battery like that? Well not totally but 6 months a year.(live in chicago)
Do you think i would have to use the tender if i dd'ed the car in the summer?
The battery is pretty rugged. It's about the most powerful one they sell. But my use is "track only", so I have no idea how it will hold up to a daily driver. You don't need something like the battery tender if the car is driven with some regularity. Its sitting for a month or more that can cause problems.
Good deal Injuneer...
personaly i would get this one 9.5 lbs less and 50 dollars more... 11.5 pounds (over 900 PCA’s), race level quality, made for daily driving...
carbon fiber battery
It weighs 9.5# less because its a lot less pulse cranking amps (904 vs. 1380). There is no weight difference between the equivalent pulse cranking amp models, whether they have the plastic (no-weight) case or the carbon fiber case.
No.
Do you think i could get away with a regular charger when its not in frequent use?
what is the pca rating of our stock batteries?
Braille sells conversion terminals, not cables. Allows you to hook up your stock cables.
http://www.brailleauto.com/productca...p?idCategory=5
