Light Bulb in Door
Old Jul 17, 2005 | 10:28 AM
  #16
unvc92camarors's Avatar
Re: Light Bulb in Door
Originally Posted by SVT03
Actually, I DID replace this bulb in my 95 Trans Am when I had it, and I am saying that you simply replace the bulb, no soldering needed.
Thank you for setting it straight also.
Old Jul 17, 2005 | 11:58 AM
  #17
Z95m6's Avatar
Ditto, They are removable bulbs. They are #74 bulbs. They are also the same size bulbs used in the HVAC panels. I ordered 5, #74 LEDS to do all the lights in my TA door panels and my HVAC. Try www.superbrightleds.com
Old Jul 18, 2005 | 12:35 PM
  #18
sscott's Avatar
I also had a hard time tring to remove this bulb. I picked up some new bulbs @ Autozone, now do you twist the plastic piece off? The end of the bulb looks like it's a wedge type why would you have to go counter and clockwise to that little plastic sleeve to replace it? It seems that you would have to just pull it to remove it, oh well leave it to GM to make things complicated.
Old Jul 18, 2005 | 04:33 PM
  #19
They do it that way to make sure it can't rattle it's way loose or anything. It sorta sucks when you turn it the wrong way though and break it
Old Jul 18, 2005 | 05:53 PM
  #20
sscott's Avatar
Mission accomplished, piece of cake. The bulb went in no problem. No splicing or soldering needed.
Old Jul 18, 2005 | 09:29 PM
  #21
SFB767's Avatar
Thumbs up Re: Light Bulb in Door
Awesome!
Now tell me how you did it.
Old Jul 19, 2005 | 04:27 AM
  #22
sscott's Avatar
It was very simple, I wiggled the bulb a little bit and it came right out. You probably need to use a paper towel or tissue when pulling reason being is that my hands slipped tring to remove the bulb from perspiration because it's so @amn hot down here. Just have some patience it will come out. The whole job from start to finish, eight minutes tops.
mattstrike
Mar 24, 2015 02:11 PM
silvermansteve
Mar 4, 2015 05:02 PM
squarehead
Jan 15, 2015 07:02 PM
siguy
Nov 27, 2014 10:07 AM
