left sde brake skids
Old Mar 24, 2016 | 06:55 PM
2000z28err's Avatar
hey guys, I got a problem with my brakes. the other day I was driving and someone cut me off, and i slammed the brakes.and the car did a fish tale. and the abs sensor light came on then shut off.. the left front side brake skids.so I went in a parking lot o test it again. and it does just that.. anyone know what could be causing this..i appreciate the info
Old Mar 25, 2016 | 12:28 PM
Re: left sde brake skids
Which light comes on - "ABS INOP" or "LOW TRAC" ?
Old Mar 25, 2016 | 03:18 PM
2000z28err's Avatar
I just tested it again..low trac light came on then shut off..and car still skids
Old Mar 25, 2016 | 03:32 PM
That means the ABS system activated, but for some reason it could not prevent the left front brake from locking up. Were you on a hard surface or gravel at the time? Sounds like the caliper may be sticking, preventing the pressure reduction by the ABS motor from eliminating the lockup.
I would examine the front brakes for wear, noting any difference between the pad thickness, and rotor wear between the left and right brakes. A sticking caliper is going to increase pad wear.
Old Mar 25, 2016 | 04:02 PM
2000z28err's Avatar
I was on a hard surface.. regular street no gravel or rain or sand. I will check the caliper. it does look like the wheel has been covered in a lot of brake dust lately, whats a goodway to tell if the caliper is good or bad ?
Old Mar 25, 2016 | 04:22 PM
The pads will be worn, possibly in a wedge shape. Compare to the right side, which does not appear to have the problem, and should have more pad left.
Old Mar 25, 2016 | 06:56 PM
2000z28err's Avatar
yea I will be checking that tommoro...
Old Mar 28, 2016 | 06:35 PM
2000z28err's Avatar
well .it was what u said injuneer..was the caliper sticking,, thx for the help
Old Mar 28, 2016 | 06:55 PM
Thanks for the feedback. Every once in a while I get one right
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
dylan1303
May 22, 2015 12:24 PM
pologreen97z
May 18, 2015 02:17 PM
Injuneer
Sep 17, 2002 12:47 PM
