Leaky T-Tops
Old Jul 20, 2005 | 10:45 PM
irocz57's Avatar
Leaky T-Tops
What needs to be changed to fix leaky t-tops at the window and any way to prevent this from happening again once fixed?
Old Jul 21, 2005 | 05:07 AM
SFB767's Avatar
Re: Leaky T-Tops
I've had this problem and there are two fixes.
The first one is to get some black electrical tape and cut very small sections and apply the tape where the leak is. My leak was always on my driver's side where the back of the t-top's weatherstripping met the front of the car's weatherstripping. This fix works, but after a few weeks of opening and closing the doors and having the windows open, you'll need to change out the tape.
The second fix is new power window motors. Mine died about this time last year and it wasn't until I had the new ones in that I realized the old ones weren't pushing the window up against the weatherstripping far enough, which is why water would trickle in during rain. Now the new window motors push the glass against the rubber so snug that there are no more leaks whatsoever and there is no more need to use electrical tape.
Old Jul 21, 2005 | 10:39 AM
DriverJ's Avatar
Re: Leaky T-Tops
weather stripping is a huge issue with these. my friend got his to wear less on his weather striping when he put his Subframe connectors on, but I recommend replacing the weather stripping
Old Jul 21, 2005 | 12:11 PM
matt65's Avatar
Re: Leaky T-Tops
Welcome to the board!
New weather stripping. I also make sure that I keep the stripping clean and armor-alled (or similar product) regularly. A lot of sun over time can really dry them out and cause stiffness and then leaks.
magman
Apr 15, 2016 03:08 AM
Z Power
Sep 19, 2015 11:19 PM
WPHIG2
Aug 27, 2015 06:37 AM
TGGodfrey
Aug 17, 2015 08:43 PM
