Leaking power steering fluid.
Today when I was driving I heard a whining noise and just figured it was the 12 bolt. But when i got out and looked behind the car there was a trail of fluid which ended up being power steering fluid. I havent had a chance to dig into it yet but It looks like the largest hose off the resivour was leaking. I know a whining pump is indicative of a bad pump but if its not getting fluid itll whine too right?
Is it relatively common for hoses to go bad?, Just hoping its not a hard line....
Originally posted by 96z
Im just going to replace the lines since I cant find a leak. Can the pump itself physically leak outside of the lines themselves? It was working perfectly fine before hand...
FJ Smith has a power steering leak fix kit. Here's a pic of it:
Pwr Steering Leak fixer-upper
Ok...I'm a wise guy
On a serious note, my power steering system developed a few leaks from normal wear and tear. Just repair as needed
Ryan
Ok...I'm a wise guy
.On a serious note, my power steering system developed a few leaks from normal wear and tear. Just repair as needed
.Ryan
Originally posted by IDOXLR8
Did you check the o-rings on the end of the power steering lines? No need to replace the lines if the o-rings are bad. After letting my car sit for the winter I noticed a huge puddle of power steering fluid. I traced it down and noticed that the o-ring had detroiated over time.
Ok...I'm a wise guy
Ryan
Ok...I'm a wise guy
.Ryan
stockssn2o
May 25, 2015 08:54 AM
mspennyhughes
Mar 1, 2015 03:50 PM
SMO Q
Feb 11, 2015 07:13 AM
