Large Duration/Carbed Motor Help
I need a little help dialing this carb in or deciding if I have other issues going on with the motor. I currently need to tackle the idle before I can progress to any other tuning so here it is.
Car idles at 7" of vacuum and this fluctuates rapidly +/- about 1".
Idles extremely rich.
Cam is .540/.562 lift (plus 1.6 rr's)
242/248 duration @ .050 on a 110 LSA
Had a Speed Demon on it (that idled very rich as well) which is not recommended for such high duration. Took it off and have a Summit branded 750 DP.
Does anyone have experience with larger duration cams? Should I drill these butterflys to help clean up the idle? I can play with the air bleeds on this unit if need be.
Is this low vacuum and slight fluctuation inherent with a cam of this size or one one suspect something else might be going on?
Thanks in advance....I can almost taste driving this car on a regular basis.
I can get it to idle at 1000 but the primary transfer slot is a little more than the .020 I'm looking for. The idle mixture screws are still functional but don't seem to do much to diminish the extremely rich idle.
alex5366
Mar 27, 2015 03:30 PM
NewsBot
Dec 28, 2014 06:20 PM
