Keyless entry not working need help
Old Dec 20, 2004 | 06:02 PM
1Quik50's Avatar
The keyless entry on my '95 Z28 mysteriously stopped working, so I replaced the batteries in both of the key fob transmitters. I rarely drive the car, so I'm assuming that the batteries in both transmitters died, as they were 7 years old.
Do I need to do something to get them working again or re-program them?
Old Dec 20, 2004 | 07:50 PM
Re: Keyless entry not working need help
There should not be any reprogramming needed. If you happen to need it, there is programming info on my Tech Page.
Old Dec 20, 2004 | 07:55 PM
1Quik50's Avatar
Could both of the transmitters just no longer work? Is there a way to test them? Or should I just try the re-programming strategy?
Thanks!
Old Dec 20, 2004 | 08:05 PM
Sometimes my unit does not respond correctly, but I can tell the signal is getting to the receiver in the car, because the interior lights come on (but the doors won't lock or unlock). Step 2 of the programming procedure will tell you if the fob is communicating with the receiver, but won't tell you which one is bad if they don't communicate.
Old Dec 20, 2004 | 08:16 PM
BadCo.'s Avatar
On my 95Z both keyfobs with new batteries work when they feel like it...most times it works so I dont mess with tryin to fix it
I see I'm not the only one
Old Dec 20, 2004 | 08:33 PM
1Quik50's Avatar
Should I just buy new key fob transmitters? Only available through the dealer?
Old Dec 20, 2004 | 08:46 PM
KPZ-28's Avatar
Mine worked like crap till I took it apart and dried out the condensation inside and cleaned the contacts on the membrane with contact cleaner.
Old Dec 20, 2004 | 10:45 PM
I wouldn't buy anything without some testing, first. Highly doubtful that both fobs quit at the same time, don't you think? I have heard of people getting fobs off Ebay.
Red Hawk 94
Mar 18, 2019 04:03 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
DirtyDan
Sep 28, 2009 10:27 AM
Darth Xed
12
Jun 27, 2002 07:46 PM
