keeps blowing water temp sensor's
Old Oct 17, 2011 | 05:23 AM
  #16
Re: keeps blowing water temp sensor's
Sounds backwards. The sensor resistance is INVERSE to temperature. Low resistance = high temperature, high resistance = low temperature. With an open circuit, the resistance is infinite, and the PCM displays the lowest temperature that fits in the 8-bit binary field, which usually shows up around -40*F. If you shorted the pins together, the resistance would approach "0" and the PCM would interpret that a s a high temperature, but again, it's limited the the digits that can be represented by the 8-bit field.
The PCM turns the fans on when there is a code for the temp sensor, to protect the engine. Doesn't matter whether its the low temp limit or the high temp limit.
Old Oct 19, 2011 | 05:36 PM
  #17
jrz28camaro's Avatar
well i tried doing some backtracking on all the wires but I cant find any breaks or bad grounds any where so dose that leave just the pcm?
also what do you think about wiring the fans into an open spot in the fues box so when ever the key is on the fans are on?
Old Oct 20, 2011 | 05:26 AM
  #18
Originally Posted by shoebox
I never recommend doing that. It is a waste to have them on all the time and can inhibit it from reaching operating temp when ambient temps are low. Wear on the fans and constant load on the electrical system (fans take a lot of power to run) are two more reasons not to do it. Just an overall bad idea. MHO, of course.
Shoebox already gave you the correct answer.
Old Oct 28, 2011 | 08:39 PM
  #19
well I thought I fixed the problem I replaced the wire from wts as far back as I could go and soldered the conections and replaced all the grounds with brand new ones and it seemed to have worked for a while their the engine light turned off and stayed off but the fans still wouldn't turn on. but today while driving the light suddenly came on and the fans turned on. So I swapped out the ecu with my buddy's who's worked perfect and data master once again said it's the water temp sensor. their must be a short somewhere but I just can't seem to pinpoint this problem I am about ready to take it to a shop and I don't want to because i don't have that kind of money. this is driving me nuts
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Biggiebound
Apr 21, 2015 11:28 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
