K&N cleaning question?
Old Oct 4, 2004 | 11:14 PM
Mister Will's Avatar
Question K&N cleaning question?
It's about time to clean the K&N filter element on my FIPK for my '98. The instructions are simple enough. But perhaps they are too simple. It appears when applying the oil, you are to simply pour it on one pleat at a time? However, I believe I've heard of people here "brushing" it on?
Should I pour the oil directly on the element or brush it on evenly?
Thanks in advance
Old Oct 4, 2004 | 11:40 PM
Don't Look Back's Avatar
Re: K&N cleaning question?
My filter oil has always come in a spray bottle. Did they change something? If so, I think that's the best way, spraying each section at a time.
Old Oct 4, 2004 | 11:52 PM
Compstall's Avatar
Some cleaning kits come with a sprayer, some don't and come with a flip up nozzle. If you have the nozzle, just apply it directly to each pleat, squeezing only hard enough to coat the screen. Not too heavy. Let it sit for a while before adding any more if needed to see how much it has spread around.
Old Oct 5, 2004 | 07:00 AM
87DJP2001's Avatar
Just don't drown the filters in oil, they are to be coated with ONLY a light film of oil.
Old Oct 5, 2004 | 08:55 AM
That's what I'm worried about.
Thanks for the imput guys. I'll probably do it tonight. BTW, I have the direct nozzle applicator, no spray.
Old Oct 5, 2004 | 10:05 AM
LPEdave's Avatar
If you're worried about putting on too much (which makes for a serious mess!) then on the first pass, do every other pleat, so you can see how far it soaks in after an hour of sitting. Then just go back and touch up the spots that didn't get oiled.
Dave
Old Oct 5, 2004 | 05:35 PM
stereomandan's Avatar
Yes, be careful you don't over oil it. That oil gets sucked up the intake ducting and coats the MAF sensors, causing them to not read correctly. I have the spray and it makes it much easier not to over oil. I took my MAF out and cleaned the sensors a couple of weeks after I oiled the filter just to be safe.
Dan
Sergio
Jan 27, 2016 04:27 PM
Deadbolt24
Jan 19, 2015 01:29 PM
nophix
Nov 30, 2014 10:26 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
