Interested in adjust steering rack preload.
Old Feb 15, 2005 | 07:17 PM
pHEnomIC's Avatar
I want to do the steering rack preload and see the guide on shoebox's site. I am not having trouble with steering or anything i just thought it be nice to get the steering a little tighter if its possible from that because im gonna be getting a new aftermarket swaybar soon.
I however dont know if i should even bother if i dont have problems.
I don't uinderstand the schematic. IT isn't clear what iloosen and what i tighten . Can anyone better explain where the two things are?
Old Feb 17, 2005 | 03:30 PM
pHEnomIC's Avatar
Re: Interested in adjust steering rack preload.
ttt
Old Feb 17, 2005 | 04:13 PM
OBE1 95Z28's Avatar
You loosen the larger outer "jam nut" (I didn't have a socket that big so I used a large set of channel locks), then you're going to tighen the inner hex nut, then retighten the jam nut. When I performed this procedure, the steering wouldn't return to center on it's own and I only slightly moved the center nut.
Old Feb 17, 2005 | 05:37 PM
Based on your post, I would leave it alone. It is only necessary if you have a need.
Old Feb 26, 2005 | 05:01 PM
pHEnomIC's Avatar
I attempted it but ijust dont understand what i turn. Theres a huge thing that doesnt look like a bolt that i think is the lock nut and then a smaller bolt that i think is the adjuster. I didnt want to mess with it until i asked you guys.
I was wondering if i could do this since my steering wheel is offset:
When you loosen the adjustor, does it disconnect the steering gears from the wheel allowing you to offset the steering wheel? MY steering wheel is offset and i thought this may work to put it in its correct spot.
Old Feb 26, 2005 | 05:29 PM
It does not correct steering wheel offset. That is done with tie rod adjustment.
Victor Lamb
Aug 26, 2017 02:52 PM
Fastbird93
Apr 9, 2016 07:01 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
