instrument cluster
instrument cluster
on mu instrument cluster i noticed at night the light on it is not steady it looks like its loosing some power and its causing it not to have a steady voltage is there something that might be causing it. i have a optima battery so i don't think voltage should be an issue
What happens to the volt meter on the dash when the dash lights are flickering (if that's what they are doing)? Does the needle move toward the red when the dash lights dim? The volt meter will tell you if you have a system voltage problem.
Chrisdude
Aug 31, 2002 12:08 AM
