Installing a starter kill switch: Is a 25 amp toggle switch safe?
Old May 4, 2006 | 11:17 PM
KillerTA's Avatar
I cut the purple starter wire on the passenger side and wired in a 25 amp toggle switch. Is the switch going to burn out or is that a high enough amp rating to use.
I see that some people use relays but I'm not real clear on how to hook that up and would rather not.
Old May 5, 2006 | 12:52 AM
kingslam's Avatar
Re: Installing a starter kill switch: Is a 25 amp toggle switch safe?
Drive up to my shop in Portage WI, and I will help you wire up a relay seeing as that should really be a 30 amp. But if you have a 4th gen, it already has a starter relay for the VATS (PASS KEY II).
Old May 5, 2006 | 02:39 PM
KillerTA's Avatar
Thanks for the invite but I just don't have the time (or gas money) to go all the way up there. Is it a service shop? Maybe sometime in the future because I think my fuel pump is going.
Anyways, I bought a 30 amp and 50 amp switch and am deciding on which one to use.
Old May 6, 2006 | 01:08 AM
kingslam's Avatar
30amp is fine. My shop is a custom shop, "KINGSLAND CUSTOMS" I have been doing LT1 swaps since 1995, put them is 70's muscle cars, like F-bodies and vets, and S-10 trucks, and about everything else including Porsche 944's, Datsun 240Z's and RX7's, also do superchargers and turbo chargers, custom paint, work on stock cars, we sponser 4 stockcars right now...
Old May 6, 2006 | 06:27 AM
Blue89Bird's Avatar
I wouldn't run a starter kill switch without a relay, not when for under $2 you can do it the right way and not worry about your car burning down.
Old May 6, 2006 | 08:28 AM
I would use a relay, too...or just make use of the theft deterrent relay that is already there...
Old May 6, 2006 | 02:08 PM
KillerTA's Avatar
Could you explain why a relay is needed? I don't understand why they are needed.
I ended up using a 50 amp switch. To me it doesn't seem like there is any need to worry about something going wrong.
Old May 6, 2006 | 02:48 PM
Honda Hunter's Avatar
I noticed most push button engine starts have relays.
Old May 6, 2006 | 10:45 PM
Airtight's Avatar
Originally Posted by KillerTA
....I don't understand why they are needed.
That's why you don't see what could go wrong. someone prolly can explain it better than me, but with a relay, all the power is going thru the relay, not the switch. You might be safe with what you have, but I'd much rather have a relay. They are needed because without them it can cause a fire when the switch over heats. I've seen it.
Old May 7, 2006 | 02:22 AM
MustangEater82's Avatar
Anyone have a wiring diagrahm of this?
and where are you splicing the wire? under the dash or outside the car?
Old May 7, 2006 | 04:01 AM
http://members.***.net/pitre/s2000sw.htm
Jan 23, 2015 01:13 PM
Jason Short
Jan 19, 2015 06:34 PM
Jul 4, 2005 05:00 PM
Vokabulis
Jul 25, 2002 05:46 AM
