installing poly motor mount (driver side)
Old Mar 12, 2007 | 05:22 PM
reamo04's Avatar
how do i go about doing this? i need to do a driver-side poly mount to keep my exhaust from smacking my floor board
Old Mar 12, 2007 | 05:49 PM
LiENUS's Avatar
You should do both at the same time but the poly mounts i bought from thunderracing came with directions
Old Mar 12, 2007 | 07:25 PM
CamaroBoy96Z28's Avatar
Do both. The motor needs to be supported while the mounts are removed. The Prothane mounts I have came with directions as mentioned and I also got mine from Thunder.
Old Mar 12, 2007 | 07:44 PM
theroad64's Avatar
I did Prothanes along with LTs, and they were a bigger pita than the headers. I supported the motor on jackstands (oilpan and harmonic balancer) In hindsight I'm not sure if its good for the mains to put that kind of pressure on the balancer, but it worked for me. Took a lot of cussing and patience though, and I think there is a better/quicker way. Just my two cents.
Old Mar 13, 2007 | 11:25 AM
LiENUS's Avatar
Use an engine hoist to pick the engine up and support it and change the motor mounts within a day, dont leave it overnight. Supporting by the harmonic balancer and the oilpan are both bad ideas.
Jan 5, 2015 07:14 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
