Installing headers and y-pipe tomorrow..wish my luck, and tips please??
I am installed MAC Mid-Length Headers and ORY-pipe tomorrow.
As of right now. I drenched all the manifold and collector bolts with penetrating oil.
So hopefully by tomorrow it will help my tear down of the stock parts.
The engine looks very clean, and clear of rust in most spots.
Now..
Does anyone have any tips for me???
Thanks in advance
Now..
Thanks in advance
Agreed, if they haven't been done, now is a good time. Same thing for the motor mounts. Spraying everything down with penetrating oil is a good start. Removing the coolant temp sensor from the drivers side head is also a good idea so you don't snag and break it when putting the header in. I learned that lesson the hardway. When you pull the sensor, put a catchpan underneath it as you will most likely leak some coolant out.
If you have access to air (impacts are nice for loosening up the old y-pipe even after penetrating oil), some room to spread out, it'll also help a great deal.
I have some decent pics of when I did mine but they're not up a website. I could e-mail them if you're interested.
You could use an impact and a long extension to disassemble the y-pipe. As the the actual manifold to head bolts, you won't be able to fit an impact ratchet in there.
Yea. I wish i could fit a impact gun up there for the manifold-to-head bolts. IF only life was that easy...but then again it could break a bolt in the head and make my life miserable.
If you spray down all of those bolts really good with PB Blaster, you shouldn't even need an impact, or hopefully a whole lot of "muscle." I soaked all of those bolts for a few days, when the day came for disassembly, every single manifold bolt came undone with very little effort applied on the ratchet.
Patients is key. Getting the old stuff off is pretty easy. Test thread all bolts before mounting up headers to make sure threads are clean. Don't over torque bolts to heads as just trying to go to 20 ftlbs and I ripped out one set of threads. Aluminum is weak. Really not bad job as some say. Just take your time. Oh and get the car WAY up in the air when it comes time to get new headers in as it will be much easier then. I think passenger side went in from bottom and drivers side went in from top. Good luck.
