im stumped...anyone?
Old Jan 19, 2005 | 11:02 PM
SpeedDemon02SS's Avatar
ok...if i put the rear defroster on, it goes off after about 2 minutes...and i can not turn it back on for about 10...now heres the real kicker...in that 1o minute window...i can not adjust the power seat...AT ALL! but after a few minutes...the defroster goes on, and the seat moves...anyone ever heard of this?
Old Jan 19, 2005 | 11:28 PM
IROC-T's Avatar
Re: im stumped...anyone?
The power seat and the rear window are probably on the same circut,and the Breaker fuse is kicking out,then resetting. My guess away.
Old Jan 19, 2005 | 11:47 PM
Capn Pete's Avatar
Be stumped no more!
I had this happen to my car. The power seat and rear defroster definitely share the same fuse, which in fact is a 30A circuit breaker, not a fuse.
The problem with my car was (apparently) that the defroster grid would draw too much current, and therefore overload that circuit breaker to the point where it would overheat and trip.....until it would cool back down and reset. As a quick fix, the dealer installed a new 30A breaker and it worked for awhile, but then they replaced the entire back glass so that I'd get a new defroster grid, and since then, no problems. I guess there was either too much or too little resistance across the grid?
Fortunately, this happened while my car was under warranty. I don't know what the back glass would cost to replace?? Others have had this problem, and say that using a 30A fuse instead of the breaker will remedy the problem too.....try that before replacing the back glass.
Old Jan 20, 2005 | 01:23 AM
Lower's Avatar
Here's a link to a thread with more links. All good reads, because there are some pros and cons to putting a fuse where the circuit breaker used to be.
http://web.camaross.com/forums/showthread.php?t=309741
Old Jan 20, 2005 | 01:28 AM
mullettour's Avatar
Originally Posted by Capn Pete
Be stumped no more!
Capn pete is a good guy for a canuck
Old Jan 20, 2005 | 05:59 PM
Capn Pete's Avatar
Thanks, eh.
Old Dec 14, 2005 | 08:32 AM
Is replacing the breaker with a fuse going to damage anything down the road? Or get too hot and melt the panel?
Old Dec 14, 2005 | 09:07 AM
cwaldt's Avatar
My driver's seat won't stop moving with the breaker in. So I just waited til my seat got to where I wanted it and pulled the breaker. Only bad thing is no rear defroster. But then again it stays in the garage.
Old Dec 14, 2005 | 12:42 PM
IROC-T's Avatar
Why not replace the seat switch,or just unplug it under the seat,then you can put the breaker back for the window.
Old Dec 14, 2005 | 01:22 PM
cwaldt's Avatar
I'm too lazy. I know I need to fix it, I just don't think about doing it much. I had the switch disconnected a while back but the side of my leather seat was tearing so I had a friend fix it, but when he put the seat back in he hooked everything up. Now that it's starting to get colder I'll probably unplug it just in case I'm out somewhere and the rear window freezes up
