Im new to the LT1 world
Old Feb 24, 2012 | 11:58 AM
madcap's Avatar
Ok guys I have 1973 camaro frame up resto but i just bought a 1997 Z28 yesterday and have no idea about the car or its specs so i am reaching out hoping for your knowledge on these subjects
*my motor looks stock but seems to have aluminum heads magnet doesn't stick to them
*what tranny is in it it is a automatic has OD D 3 2 1
*what gears are in it
*whats the best and easiest thing to do to make it fast my 1973 runs a 9.8 1/4 i want this one to do about a 10.5 street car
All comments and knowledge will be greatly appreciated
Old Feb 24, 2012 | 12:06 PM
Re: Im new to the LT1 world
All F-Body (Camaro, Firebird) and Y-Body (Corvette) LT1's have aluminum heads. The B-Bodys (Caprice/SS/Roadmaster/Fleetwood) have cast iron heads.
The 97 has a 4L60E electronically controlled automatic trans, with a pulse width modulated converter lockup.
The automatics came with either 2.73 (RPO "GU2") gears in the base configuration, or with 3.23 (RPO "GU5") gears if the original buyer checked the "performance rear axle" option on the order form. Check the parts code tag in the glove box for those codes.
To run 10's it's possible to build a normally aspirated engine, which along with a good drivetrain, suspension and some weight reduction will get you into the high 10's. It's a lot easier to do it with a blower or nitrous. People have taken the LT1 into the low 8's.
Helpful links:
4th Generation (1993 - Present)
Rebuilding the Chevrolet LT1 Engine, Doug Anderson, Automotive Rebuilder, September 1999
4th Gen LT1 F-Body Tech Aids
Old Feb 24, 2012 | 02:30 PM
madcap's Avatar
so will i need a special stall convertor
Old Feb 24, 2012 | 03:32 PM
Dave89IROC's Avatar
For what? Just one for a small block Chevy, 4L60e trans in the stall speed of your choice, nothing special
Watk69
Feb 25, 2015 11:13 AM
feraldrood
Feb 3, 2015 03:57 AM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
lt1car
Sep 10, 2002 11:50 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
