If Anyone needs RPO/Option codes defined..
I have a book that lists *ALL* RPO codes from 67-02..Camaro's... Still working the Firebird/ Firehawk/Trans Am angle.
-Found a place for the Pontiacs...Hit me up...
Put 'em in here...
I'll get em for ya... Either post a REASONABLE size pic of the sticker, or type them in.
Put 'em in here...
Re: If Anyone needs RPO/Option codes defined..
Only 1 set I don't know..2000 Camaro V6 auto
6PW - Component FRT LH Computer SEL SUSP
7PW - ........"...... FRT RH .........".................
8TJ - ........"...... RR LH ........".................
9TJ - ........"...... RR RH ....... ".................
Thanks..!
Thanks..!
The 9TJ was traced back to the Firehawk package... My book didn't have them listed. It has everything for the camaro heritage, but not this one.
Got it!
No 6/7PW...
6PU LEFT FRONT SPRING P/N 22133438 (45.5 N/MM, 257 LBS/IN)
7PU RIGHT FRONT SPRING P/N 22133438 (45.5 N/MM, 257 LBS/IN)
8TJ LEFT REAR SPRING P/N 22077421 (19.9 N/MM, 114 LBS/IN)
9TJ RIGHT REAR SPRING P/N 22077421 (19.9 N/MM, 114 LBS/IN)
Got it!
No 6/7PW...
Thanks..!
Thanks..!
Originally Posted by 99_Z_155
you could just go to camarosource.ca. they have an automatic decoder. type em in and it gives em to ya.
This guy has the info and is gracious enough to do the work.....THANK YOU..!
My car also has the F41 "SUSPENSION SYSTEM FRT, RR, FIRM RIDE, HANDLING".
Are those springs automatically part of the F41, or is the spring set something special that can be ordered over & above the F41...anybody know..?
Again, Thanks...Bayer.
Here's another source: WWW.LoneStarThunder.com/m_rpo.php
What year is the car? That comes up under a 2nd Gen...Still searching.
Hope this helps a bit. It does say Nova, but there are also referances to the Camaro F41 suspension package.
http://www.novaresource.org/rpo_F41.htm
http://www.nastyz28.com/faq/suspen.htm
The F41 package was a special performance suspension package designed to make the Nova handle corner better. Early on it was only available on the SS (1968-72) and it was a set of special springs (1968-69). For 1970 it changed to being special front and rear shocks and anti-sway bars. The standard suspension front anti-sway bar was .6875" (11/16") but the F41 front bar was .8125" (13/16"). F41 also added a rear .5625" (9/16") anti-sway bar. For 1973-74, the equipment didn't change but the availability did. The F41 was now available on non-SS cars as long as front disc brakes were ordered. With the revised chassis of the 1975-79 Nova, the F41 packaged was revised too. It was now available on any Nova as disc brakes became standard in 1975. The shocks were still special but the front anti-sway bar grew to 1" compared to the standard .875" (7/8") bar and the .9375" (15/16") bar used on the Concours and Customs. The rear anti-sway bar remained the same at .5625" (9/16"). Lastly, 14x7" rims became part of the 1975-79 F41 package.
The Nova F41 suspension was similar to the Camaro Z28 and made the Nova as good at the Camaro when it came to turning corners. The F41 also became the platform on which the 9C1 Nova Police Package was built upon. The Nova Police car was very good and served police departments well for many years. This is just another example how the Nova was able to do all and be all when properly equipped.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
BigDarknFast
3rd Gen / L98 Engine Tech
Jul 8, 2002 01:37 AM
