I dropped a rench on my battery... whats wrong?
Old 04-29-2017, 05:07 PM
Tatie Roper's Avatar
Lightbulb I dropped a rench on my battery... whats wrong?
I have a 1995 chevy camaro basic modle 3.4 I was replacing my battery and droped my wrench on the battery. There was high spark from the battery and now it wont start i had the battey checked its good the starter and alti was great. I cant find out the problem ive even checked the fuses they still work..helpp.. btw i love working on cars but im stomped for this one
Tatie Roper is offline
Old 04-29-2017, 05:36 PM
Re: I dropped a rench on my battery... whats wrong?
Not much traffic here in "Advanced Tech", which is one of the the reason it indicates "Do Not Post Here".
Let's move this to "General 67-02 F-Body Tech"
Injuneer is offline
Old 05-08-2017, 07:41 PM
GaugedFreak's Avatar
Have you checked all of the fuses under the hood and inside the driver door? Does it do anything at all?
GaugedFreak is offline
Old 05-08-2017, 09:14 PM
No just the lights work i tested thr fueses they were ok but which ones do i test excally?
Old 05-08-2017, 11:39 PM
Fatdog2's Avatar
Will the car try to start,or is there nothing at all when you turn the key on?Any clicking noise?There is a fuse box under the hood,open it up and pull each fuse out and look at it (I use a flashlight) and see if the grey aluminum thing is broken in the middle of the fuse. Hope this helps.Also did you try to start in neutral?
Fatdog2 is offline
