How is your power steering?????
Old Sep 19, 2004 | 01:22 AM
Blue96z28's Avatar
Just wondering whats up with mine, it has always been sort of stiff, and lately its been getting worse, i did a half-*** flush job awhile back, which did absoutely nothing to fix the problem, no leaks, looks clean
Is it supposed to be really easy to operate?
Old Sep 19, 2004 | 01:27 AM
Blue96z28's Avatar
Re: How is your power steering?????
and also , what are the stock idle speeds, fully warmed up, with & without the AC on?
Old Sep 19, 2004 | 01:34 AM
97WS6SCharged's Avatar
My power steering is tight and easy to operate. I've never had any problems from it. As far as idle speed goes, my 6 speed car has always idled around 900-1000 RPM.
Old Sep 19, 2004 | 01:54 AM
tomatocity's Avatar
I bought my 95 Z28 in February and the power steering has always seemed stiff or not easy to steer. I thought it had to do with the rack & pinion steering. My S10 steering is MUCH easier to use than the Z28.
Old Sep 19, 2004 | 08:34 AM
93transam1234's Avatar
my steering id stiff, i am pretty sure that is how it is suposted to be. I wouldnt say it was hard, just takes a lil getting used to
Old Sep 19, 2004 | 09:24 AM
)2overt SS's Avatar
My power steering isn't stiff at all... then again my beater doesn't even HAVE power steering... so maybe that's why lol
Old Sep 19, 2004 | 11:36 AM
Jeffs94Z28's Avatar
The only problem with my steering is occasiocally one of the hooker long tube headers brushes against the steering shaft.
Old Sep 19, 2004 | 02:15 PM
tomatocity's Avatar
The rack & pinion unit is supported by four rubber bushings. I wonder if they could have softened and the unit moves around? There are Polyurathane busings made for replacement.
Old Sep 20, 2004 | 07:19 AM
Jeffs94Z28's Avatar
I think im going to bend the header in a little more.
Old Sep 28, 2004 | 05:08 PM
Blue96z28's Avatar
yeah mines just always slighly stiff and you can tell i difference in smoothness when the car idles down, or with the A/C on.....just wondering what to expect....
Old Sep 28, 2004 | 06:51 PM
Slappy3243's Avatar
Yeah, my power steering is stiff compared to any other power steering car that I have driven. I personally like it like that though. My car idle's around 600-700 rpms. I also drive a 6-speed.
Old Sep 28, 2004 | 09:25 PM
slayer6x6's Avatar
Mines noisy
Old Sep 28, 2004 | 11:55 PM
tomatocity's Avatar
Originally Posted by slayer6x6
Mines noisy
it should not be noisy enough to be noticable.
Old Sep 29, 2004 | 12:42 AM
Blue96z28's Avatar
mines not really noisy, never heard anything odd, but its just kinda stiff all the time, and with A/C on and warmed up, low idle, it will almost cut out if you use it alot, for a few milliseconds, like "lag" in the middle of turning.....rought spot kinda thing.....
Old Sep 29, 2004 | 03:27 AM
tavella's Avatar
My power steering has gotten looser and looser. Often if I hit a groove in the road, my car will follow it. It hasn't been the same since I had the tires changed and the guy from "Wrong Turn" who was I'd say 300lbs+ drove it in and out of the shop.... I was told by GM that my high pressure hose was leaking but my fluid level hasn't changed in the past 8 mo since I was told that... I'm lost.
