How is your power steering?????
Just wondering whats up with mine, it has always been sort of stiff, and lately its been getting worse, i did a half-*** flush job awhile back, which did absoutely nothing to fix the problem, no leaks, looks clean
Is it supposed to be really easy to operate?
Re: How is your power steering?????
My power steering is tight and easy to operate. I've never had any problems from it. As far as idle speed goes, my 6 speed car has always idled around 900-1000 RPM.
Originally Posted by Jeffs94Z28
The only problem with my steering is occasiocally one of the hooker long tube headers brushes against the steering shaft.
yeah mines just always slighly stiff and you can tell i difference in smoothness when the car idles down, or with the A/C on.....just wondering what to expect....
Yeah, my power steering is stiff compared to any other power steering car that I have driven. I personally like it like that though. My car idle's around 600-700 rpms. I also drive a 6-speed.
mines not really noisy, never heard anything odd, but its just kinda stiff all the time, and with A/C on and warmed up, low idle, it will almost cut out if you use it alot, for a few milliseconds, like "lag" in the middle of turning.....rought spot kinda thing.....
My power steering has gotten looser and looser. Often if I hit a groove in the road, my car will follow it. It hasn't been the same since I had the tires changed and the guy from "Wrong Turn" who was I'd say 300lbs+ drove it in and out of the shop.... I was told by GM that my high pressure hose was leaking but my fluid level hasn't changed in the past 8 mo since I was told that... I'm lost.
