How well do the spiral type bullet mufflers flow?
Old Jun 16, 2006 | 11:22 AM
BLUETOPTA's Avatar
Some one told me that the spiral type bullet mufflers that a few companies make flow for crap. Is this true? Anybody have any numbers on this?
Old Jun 16, 2006 | 11:42 AM
Gripenfelter's Avatar
Re: How well do the spiral type bullet mufflers flow?
I heard the same. I was told they were just for sound. If you look at the design you can see why its restrictive compared to a straight bullet or any other straight through muffler.
Old Jun 20, 2006 | 11:02 PM
mebanditws6's Avatar
Lane, the guy I bought my true duals from said he's seen dyno tests of Flo Pro Twisters and Bullets, and they were the same. The Twisters may flow slightly less then Bullets, but it's not enough to show up on a dyno, much less on the street. If anyone tells you the Twisters flow poorly, they're just speculating.
Jason
Old Jun 20, 2006 | 11:37 PM
speed_demon24's Avatar
Jason
Indeed. Also the spiral flows go out into the 4" case instead of just staying 3" inside, which gives them more area inside than a bullet.
Old Jun 21, 2006 | 09:11 AM
jsetzer's Avatar
Also, depending on who makes them they can vary.
I went to a local exhaust shop to get mine and he showed me several different ones. Some had HUGE louvers(sp?) in them. The ones I got had a 3" inner core but very tiny fingers sticking out. So they are almost a straight though.
Old Jun 21, 2006 | 12:35 PM
Were talking about spiral flows, you're probably talking about a sweet thunder or something similar....
Old Jun 21, 2006 | 12:43 PM
Sweetred95ta's Avatar
What about the Moroso Spriral Flows? I guess they are similar to a Twister.
Old Jun 21, 2006 | 02:51 PM
97WS6SCharged's Avatar
Pretty much. They have a 1" open pipe that runs down the center with the baffles wrapped around it. Either way, neither the proflos or the spiral flows will be a restriction on the street.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
generaldave
Sep 25, 2015 06:48 PM
Slayer
Aug 17, 2015 03:55 PM
Aug 17, 2015 09:50 AM
