how to tell clutch master cylinder is bad?
Old May 4, 2004 | 01:57 AM
coogsLS1's Avatar
just as the title says....jw
Old May 4, 2004 | 06:20 AM
Kataklysm's Avatar
When mine went out the clutch wouldn't pop back out. I'd push it to the floor to shift then it would just stay there, I had to use my foot to pull it back out.
Old May 5, 2004 | 02:50 PM
coogsLS1's Avatar
anything else happen? Id hate to think I need a new clutch and then find out its just a master cylinder
Old May 5, 2004 | 05:27 PM
Kataklysm's Avatar
Not that I noticed, after the first day that happened I got it fixed...NO way I was gonna drive like that.
Old May 6, 2004 | 02:01 AM
Decap92RS's Avatar
After a WOT run down the road, i tried to downshift to slow up for a stop sign. It was as if I had no clutch, and the clutch pedal was not popping back out. Unlike Kataklysm, mine wouldnt pull back out. I immediately thought clutch, and swapped the clutch (which was damaged). Still problems. Changed the master cylinder, and worked great. The clutch problem had nothing to do with what happened, but it was a fairly oppertune time to swap dont ya think?
Old May 9, 2004 | 12:18 PM
XxXTransAmXxX's Avatar
Another way to tell is, if you have to practically push it to the floor to get the clutch to actuate...my buddie's 95 TA did this, and he replaced the Master Cylinder and Slave Unit, and evertying is fine now...
Old May 9, 2004 | 01:59 PM
Kataklysm's Avatar
The master isn't expensive so may as well give it a try if the clutch is acting up, why get in an accident if you can avoid it?
Rod Bender
Nov 7, 2023 02:30 PM
Rod Bender
May 16, 2015 02:16 PM
timmy39120
May 2, 2015 05:12 PM
Ringmaster72
Mar 19, 2015 03:32 PM
siguy
Nov 27, 2014 10:07 AM
