how to replace AC drier properly
Old Jun 11, 2007 | 03:26 PM
got_hp?'s Avatar
When I dropped in my 383, obviously the AC stuff was all disconnected. I havent driven the car much so hadn't bothered to get it recharged. The friend who installed the engine for me said to get a new AC drier since and then have the freon recharged.
Ive got the part, just want to know if there are any special instructions for installing it, or if anyone has a guide?
Old Jun 11, 2007 | 03:28 PM
Executioner2k5's Avatar
lube up the o rings put a few oz's of oil in the drier and screw it into place
Old Jun 11, 2007 | 03:50 PM
got_hp?'s Avatar
Thanks,
what kind of oil?
just squirt it into one of the openings where the orings go?
also just thought of this, do i need to release any sort of pressure valve or something to disconnect the old one?
the system is all hooked up now, even though theres no freon in it and the drier was exposed.
Old Jun 11, 2007 | 03:54 PM
Originally Posted by got_hp?
Thanks,
what kind of oil?
yer drier should have come with an Oil my new one did, yes just dump some on each side where the orings are, no if their is no pressure in the system (no freon) you can take it off with out it popping off like a rocket im not sure if it takes a special oil or not
Old Jun 11, 2007 | 03:56 PM
got_hp?'s Avatar
thanks, hopefully theres no pressure, lol. is there a way to check?
Old Jun 11, 2007 | 03:59 PM
yea you know where to put the freon correct? if so push that stim down and see if anything comes out if nothing happens you got no pressure
Old Jun 11, 2007 | 04:15 PM
got_hp?'s Avatar
a plastic cap on one of the hardlines right? if i remember theres 2 of them, and 1 is for input.
Old Jun 11, 2007 | 04:26 PM
yea those are them
Old Jun 13, 2007 | 02:18 AM
theratdude64's Avatar
That new is R-134A right? Does the stem you gotta push in to see if theres pressure have a thread on type like a bike tire or something, or is it a quick connect type? If its thread on its R12 and need to convert to R134A *or pay like 150 per can if you magically find some R12 haha* But I do believe something that new would be 134A already
Old Jun 13, 2007 | 08:05 AM
GreenDemon's Avatar
The connectors go on like an air fitting (quick connect), then you screw them down until they stop. You can still just push the valve in to see if it has pressure.
There are two schrader valves, one for high side, one for low. When you do a "backyard" recharge, you'll be tapping into the low side.
You're better off getting it recharged at a shop after you're done working on it, unless you have a machine to pull a vacuum on the system. You want to have all the air and moisture out of it before putting in new refrigerant. You'll be a lot less likely to have problems that way.
Old Jun 15, 2007 | 03:57 PM
CamaroZBoy's Avatar
if you open up the AC system you MUST pull a vacuum on the entire system. By having just the dryer off you would have opened the system therefore needing a vaccum. By not running a vacuum on the system you risk clogging the system with anything that could have crept into the lines while it was open to the air/elements of any sort.
Cory
Old Jun 15, 2007 | 04:47 PM
ACE1252's Avatar
Don't they also have to somehow evacuate the moisture out of the system as well?
Old Jun 15, 2007 | 04:56 PM
CamaroZBoy's Avatar
yes
Old Jun 15, 2007 | 05:22 PM
Dave89IROC's Avatar
yes, this is the main reason for pulling a vacuum on the system, to get the moisture out
Victor Lamb
Aug 26, 2017 02:52 PM
Collector Car
Jan 5, 2015 10:58 AM
Injuneer
Dec 15, 2014 09:36 AM
fpete1992
Dec 11, 2014 03:51 PM
