how to remove a 97 3.8?
Old Mar 11, 2013 | 01:34 AM
Jeffs1997's Avatar
It looks like it will come through the hood ... BUT .... is this a easier way then out the bottom?
How did you all lift your bodies up over everything once the cradle was dropped?
I have heard the bellhousing must be removed with transmission ( T5 ) connect due to the throwout bearing and one bolt on the bellhousing is extremely hard to get to.
How hard to bleed the ABS once the brake lines are back on the ABS pump?
any other pointers?
I have motor almost ready to be dropped so need opinions here.
with trans connected is there enough room to come out the hood?
Old Mar 11, 2013 | 03:13 PM
Re: how to remove a 97 3.8?
Out the bottom is the easiest, IMHO. I raised the car, then lowered the k-member down with a floor jack. The trans can stay connected. You don't have to mess with the ABS if you are careful not to touch the brakes during the procedure. Just remove the two brake pipes that go to the front wheels and fish the lines out as you separate the engine. You can probably find some engine removal threads in the LT1 section.
Old Mar 11, 2013 | 03:57 PM
Jeffs1997's Avatar
Where did you attach the hoist to raise the body?
Old Mar 12, 2013 | 07:16 AM
I didn't have a hoist. I jacked it up under the k-member. Most people will put the back wheels on top of some other wheels and raise and support the front under the jack pads by various methods.
Old Mar 17, 2013 | 12:12 PM
Jeffs1997's Avatar
thanks!!!!! I dropped it out the bottom and that is the simple way to do it, even with a V-6.
marlar98
Sep 19, 2015 07:53 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
pimpen1024
Aug 19, 2015 08:36 PM
zajones
Jul 30, 2015 02:18 PM
pimpen1024
Jul 8, 2015 09:08 PM
