How hard is a spark plug electrode?
Old Jan 24, 2007 | 12:55 AM
Gearhead6s's Avatar
I swapped plugs the other night and one of them was missing its electrode and the ground was bent. I have forged pistons with a 22cc dish, and AFR 210 heads on my turbo lt1. is an electrode hard enough do any damage if i bangged around in there? Motor still runs fine.
Old Jan 24, 2007 | 04:44 AM
95LT1conv's Avatar
it probably got pushed right out the exhaust
Old Jan 24, 2007 | 08:38 AM
2000GTP's Avatar
I'm sure you'll be fine, afterall, the stock platinum plugs are notorious for dropping their pucks through the engine as well.
Old Jan 25, 2007 | 02:31 AM
angel71rs's Avatar
Might want to scope that cylinder. Only time I've seen a ground post bent was when a chunk of piston breaks off at the top ring land. Detonation can destroy center electrode, but won't bend the ground that I've ever seen. Could anything have fallen into that cylinder to cause the damage?
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
