How to fix Interior leak?
Old Oct 26, 2006 | 04:31 PM
crAzy95z28's Avatar
Well i just noticed during rain. My car seems to build up a pile of water both front and rear passenger side. Its not comming in through the window i know this. But it seems as if its comming in from the outer side of the car and leaking down to the floor board.
Any way to fix this?
Old Oct 26, 2006 | 09:43 PM
deputydough's Avatar
probably you window moulding is torn or pulled from the car. it will channel the water down the door and inside the car. check it all the way around the door.
Old Oct 26, 2006 | 10:00 PM
oneslowz28's Avatar
The door molding can also become "weak" and cause a leak. it will look like its sealing when in reality there is a tiny tiny gap or small hole in it that is letting the water in.
Old Oct 26, 2006 | 10:14 PM
crAzy95z28's Avatar
i think i found the prob. The grommet on teh passenger side fire wall is missing. I ran a nitrous line through there. SO i 99% sure thats whats causing the major leak.
Old Oct 26, 2006 | 11:30 PM
oneslowz28's Avatar
unless your cowel foam weather stripping is shot there is no way that that could cause that much water to leak in.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Brake_L8
Jan 20, 2015 09:44 AM
squarehead
Nov 21, 2014 08:02 PM
MislMan
Jul 19, 2002 11:41 AM
