How to? Factory exhaust tip alignment.
Old Feb 3, 2006 | 07:20 PM
Northernrocket's Avatar
Hi all, the name is Brian and I just recently purchased a 1994 Z28, 6spd. I picked up a set of factory Z28 exhaust tips to replace the plain pipes now on the car and was wondering how the tips where centered from the centerline of the car from factory, as they are both offset in the same direction? Seems odd I would have thought one would go to the left and one the right but not so.
Brian Duffett
1980 442 W30
1968 Cutlass S Conv. 425ci
1994 Z28 LT1
www.geocities.com/nrthrnrckt
Old Feb 3, 2006 | 07:31 PM
Blue89Bird's Avatar
Re: How to? Factory exhaust tip alignment.
one goes one way, the other goes the other.
Not trying to be rude, but they can only go 2 ways, just try it out
Old Feb 3, 2006 | 07:46 PM
Not that you are sounding rude at all, but I wish it was that easy. Maybe I have been sold 2 for the same side but I have seen a few sets sold the same way these where. When viewed from the top and what would be the rear of the car they both seem to have the inlet to the left. Did the factory tailpipes have a jog in them to make up for this or was it accomplished just by the distance before turning to the rear of the car after exiting the muffler?
Brian Duffett
1980 442 W30
1994 Z28 LT1
Old Feb 3, 2006 | 08:00 PM
Chrisz24's Avatar
I know what you mean.
They are both one direction and I think the passenger pipe is pushed more to the center so that tip allignes up in the same spot on both sides of the car.
|__\
Sorta like that, but on both sides.
Check out the last page in my sig, I have a firebird exhaust and it looks exactly like the camaro Z28 one. it will give you an idea of how the factory one looks.
~Chris
Old Feb 3, 2006 | 08:11 PM
Thank-you Chris. That is exactly what I needed. I looked all over for a photo showing that layout. There are all kinds of shots of aftermarket stuff and I don't think is a Camaro in our area that hasn't had the exhaust modified.
Thanks again,
Brian Duffett
1980 442 W30
1994 Camaro Z28 LT1
Old Feb 3, 2006 | 08:23 PM
TraceZ's Avatar
The tips both taper the same direction. The pipes do not exit under the bumper in exact opposite locations. The passenger side pipe is more towards the center. The tips are then put on to make it appear to be centered.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 08:12 PM
