How does the keyless entry receiver get the signal?
I'm trying to retrofit a factory 95 keyless entry system in a 93 car. I didn't see any wires listed for an antenna or some other signal receiver. Does it get the signal from inside the box?
Re: How does the keyless entry receiver get the signal?
Originally Posted by Mtrhds94Z
The module under the dash is the receiver and there is no antenna.. I would think the antenna is inside the module..
does your car have powerlocks and windows, because I always thought the Keyless entry was in the same module as the keyless entry. Am I wrong here? Is that module just for keyless entry?
It's kind of hard to have keyless entry without power locks.
Originally Posted by moparman
How does one test to see if the transmitter or the receiver is bad?
yeah that didnt make any sense. Are power locks controled out of the same module as the keyless entry? Thats what I meant to say
When you use the switches on the doors, the circuit to the locks still passes through relays in the receiver, but the receiver does not actually operate. It's relay contacts allow passing of the voltage or ground through a set of contacts that "make" (or connect) when the relay is in an unoperated state.
CARiD
Sep 7, 2015 08:21 AM
