How do I make a kill switch for my 97TA ?
Old Mar 18, 2006 | 06:30 PM
KillerTA's Avatar
I want to hook up a kill switch but am not sure how or what I need to do it. I also saw this on ebay http://cgi.ebay.com/ebaymotors/ws/eB...tem=8020818830 Is it worth buying?
Old Mar 18, 2006 | 09:28 PM
Camarocracy's Avatar
Re: How do I make a kill switch for my 97TA ?
It would cost you $5 and some time to do it with parts from radioshack. I don't have a write-up, but you can do it a lot cheaper then that.
Old Mar 18, 2006 | 11:59 PM
TraceZ's Avatar
Your car already has VATS. Why do you want a kill switch? The VATS will disable the fuel pump, starter and ignition.
If someone is smart enough to get around the VATS, they are surely smart enough to bypass your simple kill switch. They would have to be seriously determined to get your car.
In most instances when a car with VATS is stolen, it is towed.
Old Mar 19, 2006 | 09:39 AM
KillerTA's Avatar
I want the added security and it's cheap.
You'd have to know where the kill switch is in order to start it. Vats can be overridden by someone who knows what they're doing, a kill switch can't unless they know where it is.
Old Mar 19, 2006 | 09:52 AM
TraceZ's Avatar
Then all you need to do is go to Radio Shack and get a Single Pole Single Throw (SPST) switch along with some 12 ga twin lead wire. Locate the +coil wire and splice into it. Poke the wire through the firewall and mount the switch inside the car somewhere. Hide your wires really well and you are done.
Old Mar 19, 2006 | 10:27 AM
MyShibbyZ28's Avatar
The thing with a kill switch is how easy they are to find. It is a good idea, but in order for you to use it you would need to have it in a semi-easy area to access. If someone is smart enough and thinks there might be the possibility of a kill switch all that person needs to do is feel around. On the other hand, most people don't think of a kill switch being in the car, they just worry about VATS and noise.
Old Mar 19, 2006 | 11:07 AM
97FormulaWS-6's Avatar
I've got one in my car, I've yet to have someone figure out how to start my car when I throw them my keys with the challenge... and I've owned the car for 6 years.
Check out Brent94Z's website, there are step-by-step instructions there on a kill switch; then just "modify" those instructions for the actual switch to as far as you can imagine.
Old Mar 19, 2006 | 03:41 PM
You can also add dummy switches. Put a couple switches with wires coming off of them in common locations but keep the real switch somewhere else.
Old Mar 19, 2006 | 06:13 PM
Or make the switches all in line so there's like 5 you have to turn on in sequence. That'd stop them
Old Mar 19, 2006 | 10:24 PM
whaler1582's Avatar
where is Brent94Z's website? what is the webaddress?
thanks,
Joshua Walters
Old Mar 19, 2006 | 10:49 PM
MasterEvilAce's Avatar
http://www.bfranker.badz28.com/
meissen
Jun 1, 2015 07:59 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
Rich_z28
Aug 29, 2002 10:44 PM
