How to change high side AC schrader valve?
I've got a 98 z28 with an AC leak that I tracked down to the high side schrader valve. Problem is, the typical valve tool does not fit over it and the port is too tight to fit a set of needle nose pliers in there.
Please help or suggest any ideas..
Thanks for reading!!
Mike
msb6807@yahoo.com
Mike
msb6807@yahoo.com
Re: How to change high side AC schrader valve?
you need special a/c schrader valve installer/removal tool. You might want to take a trip down to the auto parts store and see if they have one you can buy or rent. And I'm assuming you have a new valve already but if not I"m sure the auto parts store will have some.
i tried that already.. the special tool only fits the suction (low) side valves. The notches on the tool are too small to fit over the high side valve.
thanks for the response.
Wow, I don't know how you get a pair to fit in there.. must be pretty small.
I may just go to a tool shop and buy the smallest vice gripes I can find.
Jul 4, 2005 05:00 PM
