Hissing noise when turning a/c off
Old Oct 4, 2012 | 04:09 PM
Lilatlboy6969's Avatar
My a/c makes a hissing noise when I turn it off for a few seconds then quits? Would this be a vaccine leak or normal operation
Posted from Camaroz28.com App for Android
Old Oct 4, 2012 | 04:20 PM
Re: Hissing noise when turning a/c off
Are you talking about inside the car when you move the mode control? It is vacuum operated, so yeah it will hiss for a few seconds as it bleeds off the vacuum. It has nothing to do with a vaccine.
Old Oct 4, 2012 | 04:27 PM
Meant to say vacuum. Stupid auto correct. But anyways I was wondering because where all 3 vacuum lines meet at the check valve under the hood in my car had no check halfheartedness it was just a 3 way port for them all 3 to connect to. It was shaped like a fork in a road so I replace it with the correct check valve from GM. Wanted to make sure I didn't screw anything up
Old Oct 5, 2012 | 06:48 AM
With the correct part, you are probably now getting proper vacuum and that may be why you are hearing a difference.
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
squarehead
Nov 21, 2014 08:02 PM
Duke
Sep 3, 2002 02:48 PM
formula79
26
Aug 5, 2002 12:21 PM
