High/Low Beam Toggle has trouble working.
Old Aug 7, 2005 | 10:04 AM
scmudslinger's Avatar
Sometimes when I try to change from low beams to high, the switch does not click, and the lights do not change. Usually to counter this I can tilt my steering wheel up high and change the lights then. I have a 93 Z28 and my girlfriend has a 94 V6 and she has the same problem. Does anyone know what is causing this, can I fix it myself, or how much it will cost/what will have to be done to fix it? Thanks for the help.
Old Aug 7, 2005 | 10:15 AM
GT KILLER's Avatar
Re: High/Low Beam Toggle has trouble working.
I have the same exact problem. Sometimes it works and sometimes it doesn't. It almost always works if I put the wheel up high, just like you. I've been wondering what this is all about.
You probalby need to adjust the switch position. The rod that activates it may not be engaging it all the way. The switch is on the lower part of the steering column, under the dash. You can see some pictures of it in my ignition switch replacement guide on my Tech Page.
Old Aug 7, 2005 | 10:20 AM
Thanks, I will try this
Old Aug 7, 2005 | 10:24 AM
What do I need to remove to get to this? The big flat panel with the two screws or what/what else?
Old Aug 7, 2005 | 01:23 PM
The ignition switch guide previously mentioned should show you how to get to it. It depends on how flexible you are as to how much access you need.
Aaront810
Aug 29, 2020 09:34 PM
Ericksd
Jan 20, 2016 06:07 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Schul365
Aug 22, 2015 10:00 AM
