High car temperature
Re: High car temperature
The engine/cooling system is designed to operate with the needle in the middle of the gauge = about 210°F. If the temperature reaches 226°F both fans should turn on at low speed. If the temperature reaches 235°F both fans should switch to high speed
Failure to operate as above can be due to common causes like:
- air trapped in the cooling system
- crudded up/corroded internals in the cooling system
- failure of a fan
- faulty coolant temperature sensor - the one in the water pump housing that feeds temperature reading to the PCM
- radiator fins clogged with dirt, debris, or front of radiator blocked by plastic bag.
- failure of pressure cap to maintain system pressure (18 PSI)
- low coolant
- collapsing water pump suction hose
- missing air dam under front bumper, if overheating occurs at high speeds.
The gauge is fed from a different temperature sensor in the driver side head. A problem with that sensor/circuit can cause an incorrect gauge reading.
Have you checked coolant level? Have you bled air from system? When was the cooling system last flushed and new coolant installed?
- failure of a fan
- low coolant
