Help, window motor stuck down, rain coming!
Old Jun 3, 2007 | 10:49 AM
vin1382's Avatar
My passenger side window motor is toast, i doubt ill be able to get a replacement today, and the remnants of tropical storm barry are on the way up. I can put it in my garage, but i need to take the car to work tomorrow and its supposed to rain all day. Is there any way i can manaully put the window up just until I can get a new motor?
Help!!!
Old Jun 3, 2007 | 05:15 PM
Lunch Box's Avatar
When my window motors went if i let them sit for a while I could get it creep back a little at a time slowly, that might work for you if you havne't already tried to
As for manually making the window go back up I'm sure if you took the interior door panel off you could manually movie it back up but i'm not sure how well that would work or if the window would stay in place, worth a try though
Old Jun 3, 2007 | 05:33 PM
Jamon's Avatar
I had that problem for a while.
Pull the window up all the way, measure and cut a block of wood to support the window up. Extremely ghetto but it's what I did till I was able to get a motor for it and get it fixed. Works like a charm.
Old Jun 3, 2007 | 07:10 PM
matLT1's Avatar
Help!!!
Once your car is in the garage, remove the interior panel as though you were going to replace the window motor. Now, what you will want to do is remove the window motor that is currently installed; this will allow you to manually lift the window such that it is fully up. Once you have it up and held in place (C-clips work well, but don't tighten too much), reinstall the window motor so that it can hold your window in place.
Old Jun 3, 2007 | 07:35 PM
vin1382's Avatar
hmm...good idea. Thanks.
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
