HELP! Removing rounded header bolt...
Old Jun 21, 2004 | 02:21 AM
Hawaii93z28's Avatar
Hi All,
Well, my header install is going a little less well than expected. In removing the old headers I slipped and rounded the head. It's the bolt furthest front on the pass. side. Any ideas how I can get this? All help is appreciated...
Dave
Old Jun 21, 2004 | 02:30 AM
99blackSS's Avatar
If you can't get pliers on it, I would take a dremel tool to it and make a deep line across the middle of the head. Then unscrew it using a flathead screw driver.
Old Jun 21, 2004 | 04:55 AM
browneye97ss's Avatar
You could also go to Sears and pick up one of their 'rounded bolt head' sockets. Not sure exactly what they call them. They have a set of sockets designed to take off bolts that the heads have been rounded off on. They also have screwdriver bits designed to remove stripped out screws. Just an idea.
Old Jun 21, 2004 | 08:01 AM
Red96Lt1's Avatar
I have taken a dremel to put some more flats on the bolt and used the next size smaller wrench.
Old Jul 19, 2004 | 12:11 AM
rossmatt06's Avatar
Re: HELP! Removing rounded header bolt...
If possible, I mig welded nuts or bolts onto the stripped one and it solved the problem everytime. (Be careful not to hit a fuel line or anything flamable!)
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
drptop70ss
May 4, 2015 08:22 PM
alphaauto
Jan 23, 2015 07:42 AM
thenewkid
Nov 18, 2014 12:57 PM
