Help! Rear side markers won't light up!
Old Jun 24, 2006 | 05:07 PM
fragenstein's Avatar
I hadn't noticed until recently but my rear side markers on the sides of the bumper do nothing! I changed both bulbs yesterday... no blown fuses. What can it be?!
Old Jun 24, 2006 | 05:56 PM
TraceZ's Avatar
Re: Help! Rear side markers won't light up!
Does the license plate light come on? The side markers are on the same circuit as the license plate light.
Old Jun 24, 2006 | 06:36 PM
Let ya know around 7:30 when I am home. Haven't noticed.
Old Jul 13, 2006 | 03:12 PM
The Gremlin's Avatar
Hi there. I am having the same problem as the OP where the side markers and license plate lights are out. Which fuse are the lights connected to? What is the common solution to this problem? Thanks all!
Old Jul 13, 2006 | 03:31 PM
Actually when I messed w/ the plate light to see if it worked... out of nowhere my side markers WERE working. They still work since and I've never known what fixed them out of nowhere.
Old Jul 13, 2006 | 04:30 PM
TraceZ's Avatar
The license plate light and side markers are all powered off the same wire. The wire connects to the car just behind the left tail light. If none of them work, start by looking at that wire and plug.
Old Jul 13, 2006 | 06:39 PM
Zulu-Two-Eight's Avatar
I had the same problem last week. I replaced a burned out bulb on the side markers, and it didn't work; the light was still out. Turns out there was some corrosion on the contacts. Clean them up and make sure the bulb is in tight. It worked for me.
Rod Bender
Jan 1, 2015 03:18 PM
siguy
Nov 27, 2014 10:07 AM
slocody
Feb 10, 2003 01:04 PM
RedLineRev
Jan 23, 2003 03:51 PM
