Help with play in steering
Old Jun 12, 2008 | 08:09 PM
andrew ws6's Avatar
I have a little play in my steering while driving, just changed tie rods and it helped a little , just wondering if the rack can get loose the way old steering boxs did and if there is any adjustment or if any one has any ideas?
Thanks in advance for any help, suggestions.
Andrew
Old Jun 12, 2008 | 08:34 PM
SC/TA's Avatar
I replaced the rack on mine and it took care of the play. Check the rag joint first.
Old Jun 12, 2008 | 08:42 PM
gnomee's Avatar
Yes like said above.
The steering shaft comes thru the firewall and connects to a pivot like a small drive shaft with a u-joint that connects to the rack.
That was bad on my 96 . Have someone look at it while you nudge the steering wheel it should be farily apparent if it is moving alot without moving the rack.
Good Luck!
Old Jun 14, 2008 | 10:47 PM
94_PatriotRed_Z's Avatar
Any other options I have this same problem, and dont want to replace the rack since Im short on money
Bxlt1
Sep 10, 2015 08:16 AM
rideordie
Sep 7, 2015 08:22 AM
350350
14
Aug 11, 2015 12:03 PM
Cam's maro
Aug 11, 2015 07:45 AM
Aug 7, 2015 01:26 PM
